i had my tracking done a while ago. It was one of the fancy ones with the cameras. They said they can only return it to stock alignment which i said was fine.
Anyway i have noticed the inner most part of my front tyres has become very worn. I have lowered suspension and have seen threads were this has caused similar problems but it doesnt go into the cures. I guess the solution would be to adjust the alignment away from stock to take into account the lower suspension. I dont know much about camber, toe and caster but i remember the guy i bought it off (who put in the new suspension) saying he was running 2° negative camber (i think). was that to stop the inner tread wear thing? How can i do this because i expect if i ask them to do that at the alignment centre i will get the usual, "sorry boss, can only return it back to standard".
thanks Gio.
I need to replace my tension rods so hopefully that will sort out the problem.
I will also have my tracking done again when the new tension rods are installed. Are there recommended settings for lowered suspension that will help stop this?
cheers,
Tom
PS I dont think i have the sagging spring or old shock problem as it is Tein suspension which is less than 3 years and about 15k miles old. It is more likely to be the lowered suspension ---> worn bushes on tension rods (although my tension rods are rose jointed so have no bushes but are not in a good way) -----> bad wheel alignment, in that order.
any help appreciated because i dont want to wreck my new tyres when i get my 18's back from the fixers!
