Where does this go!! Please Please Help if you can
Hi all and i hope you can help me, this is doing my head in, finally plumbed the engine and found out where all the hoses go but one, right here goes, there are vac pipes connect to the waste gates and boost solenoids above, this then comes round the front of each side of the engine, according to the manual these should then connect to the "boost gallery" and the "boost sensor" which should be somewhere under the air filter panel , mine are just connected in front of engine by vac hose, it has a hose tee'ed off this which looks like it has a boost jet crimped into the end, have no idea where this goes, and dosent it need the boost galley and sensor (which i cant find for the life of me) can some one please please please tell me what's PO has likley done? and how to find the bits.
Brian
some pics would be better
yeah i wish i hat taken my camera, but its tucked up in a garage 40 miles from me, everything else was as per manual, but cant see boost gallery or boot pressure sensor.
At the side of the Plenum there are small metal tubes stuck together,this is the boost gallery(or vac gallery!) boost sensor is next to the brake servo right in the top corner of the inner wing,
HTH! ;)
If it helps ya...you could always come over n look under my bonnet maybe once you see all the hoses in situ you can take a pic and copy to your own??
that would be brilliant if i could cant help thinking sonething is missing!
what age is your zed mate as my 96 has the boost sensor under the centre pannal
mail me at 2badd@talktalk.co.uk and we can arrange for you to come over eh :)
hi mate, tried to email you on that address and its told me there is no mailbox for that address (2badd@talktalk.co.uk) cheers
Brian
