I am about to change my N/A Jap 180 kph clock cluster for a TT UK 160mph clock cluster.
I have a couple of questions:-
1) I don't mind the turbo psi dial being there below the speedo, I just wont be using it (obviously), but are there any other problems with exchanging N/A Jap clocks for TT UK clocks?
2) I am expecting the speedo to work to 180mph although the actual dial is only 160mph. Should I be able to correct this by means of the pot?
Cheers - Dave
  • Replies 29
  • Views 1.4k
Simplest option would be to sell those Clocks and just get some Silver dials for your own clocks ?
But my clocks are Jap, the fuel gauge and odometer&mileometer do not work and where would I get silver dials? (Actually the UK cluster I have are white dials and silver facia....see photo below).
Cheers - Dave
i replaced my jap spec clocks on my na with uk twin turbo, its a straight swop. you do however get a warning chime to tell you when you decelerate to 10mph! you can unplug the chime speaker that sits ontop of the dials if this annoys you.
