digital clock dimmer wire
should be a relatively easy mod. I want to disable the dimmer of the dash digital clock so it stays on the top brightness when the lights are turned on. I am guessing it is just a single wire that needs to be chopped but anyone any idea which one and if it is simple as that?
Theres a plug going into the back but only 2 wires to my memory?? Trouble is the pod dims aswell doesn't it?? so maybe a bit more tricky knowing the zed,
Not much help really
If you don't want this to happen then cut the green/brown wire on the loom side plug or green/white wire on the clock side socket.
4 wires in the socket at the back of the digital clock: blue/wht, yellow, black, green/red.
I guess i can test which wire controls the dim with a multimeter but i dont have it on me and was wondering if anyone knew which one it was.
Maybe my red looked brown !
There should be four wires connected to the clock:
Blue/White is power from the Accessories circuit
Black is the earth connection
Green/Red is connection to illumination circuit to dim the display when the lights are switched on.
Yellow is the permanent 12 volt battery connection.
it was the green/red wire. Gave it a snip and it no longer dims when the lights are turned on. Rest of the clock is fine. tested the voltages with a multimeter before.
yellow: constant voltage
black: earth
Green/red: 12V when lights turned on causing it to dim
blue/wht: not sure.
recomend it. can now see clock when you turn the lights on when it starts to get dark. Simple to do and can reconnect the wires at a later date if you dont like it.
