dials problem..
i got these dials and few weeks ago they stop to luminate,any of you who's got these dial had any problem in the past ? i've connected the wires from transformer straight to the batery and still nothing...if is the transformer any chance to get it fixed?
:dance:
Are these the recent Group-Buy dials only they look silver and the G-B ones were white?
they are the same as mine . i had a problem with the cables to the transformer , one was broken inside the plastic PVC sheathing , also check the polarity is correct its easy to connect the positive lead to negative terminal , swap them over and try again
transformers are availableon ebay for them by the way .......cant think of the ebay number now , do a search on this forum for indiglo dials
good luck mate
Steve
they look like the ones I supplied ages ago, where did you get them from? Is the transformer buzzing at all?
Vijay
Vijay you're right ,i got these from you ages ago ...the transformer is buzzing but the dials don't light up
:dance:
Do they have a dimmer switch? I had a problem with mine and it turned out to be the dimmer switch was broken at the small PCB. I just cut the wires and joined them together. Try shorting it with a spare piece of wire before you cut them though if they light up then you know what the problem is.
you'r right ,the swich is not working no more,one of the wires is broked ,i'll try it tonight
:dance:
If that's the case mate, PM me your address and I'll sort one out for you :)
Vijay
thanks Vijay i'll try to see with the wire first and then i'll let you know thanks again
:dance:
Hello mate,
Tried to reply to your PM but you inbox is full. PM me your address :)
hello mate,please give me your number and i'll talk to you ,my number is 07738204189
:dance:
