Essex tt specialist required
Looking for a recommended garage or mechanic in Essex that has a good rep for 300 tt engine diagnostics and repaire/rebuild,as I think a cam belt has gone causing no compression in 3 cylinders :shock:
'A' cambelt? it only has 1, loosen timing cover enough so you can see the belt and turn engine over to see if its turning when the engine is cranked first
hi mate. dont know where abouts in essex you are but REDLINE IMPORTS in southend on sea are excellent. 01702 555554. give em a try.
Or speak to Mike At MJP Eastern auto in our traders section. His mechanic Carl is spot on.01277 374201
