code 26
I'm getting a code 26 on my ecu. does anbody know what voltage should be passing through the boost sensor. So i can take it to work tommorrow and get our sparky to test it for me. it's a 96 tt and the sensor is mounted at the front of the car under the slam pannal not in the top driver's side by the small fuse box like in my 92tt??
thanks in advance
graeme
Boost sensor? by that I guess you mean the sensor for the boost gauge? it must be because the ecu does not use one.
The boost gauge was deleted on the later models so no sensor was fitted, the one you mention must be for something else, take a picture and post up.
Code 26 you sure?
Daveman
yep def code 26 comes up after a ecu clear ie: leaving battery off to clear it. but before starting the engine???
will get a pic up soon
thanks graeme
