bleed valve. not working properly
ok, you guys know your shit. i need some pointers.
i have just installed a bleed valve. [yes, thankyou, no lectures]
now, i only get 6 or 7 psi out of my GTO and i wanted to see if i could get a bit more.
i installed the valve in the correct place. and opened it a bit, then a bit more......then a bit more. and i could only register about 8 psi.
anyone any ideas why this is?
i think my aftermarket boost guage is pretty accurate. i think i installed the bleed valve correctly.
why only 8 psi. with the amount i have the valve open it should have been bloody 30 psi!
and the car didn;t feel that much faster than normal, so i am sure the guage is working correctly. and i was only getting 1 psi more.
why???
please help.
cheers.
Well I know jack about how GTO's work, so it's obvious questions only. Have you got the right size bleed valve - fractions of a millimeter can be critical (assuming it works the same way as a Zed).
Originally posted by craig:
assuming it works the same way....
dont you need to make the hole smaller, not larger, to increase boost ?
You need to bleed more air off the actuator (vent it to atmosphere) to prevent it opening at a factory set level.
More air bled off actuator=wastegate opens later=more power=short engine life biggrin.gif biggrin.gif biggrin.gif
Robert.
I only use the brakes so I can accelerate all over again.
[This message has been edited by dunk300zxtt (edited 17-06-2002).]
What i cant understand is (and im really not having a dig at you) why not just get a proper boost controller. They are far more accurate and more adjustable and have safety features built into them ect? At the end of the day you could have a rather large engine bill just for the sake of not spending a bit more money on a controller.
Stupid question how were u testing it? Obviously u'll be wanting ur foot right down do a fair few revs. Ive known someone to sit on the drive revving it up..." it aint got no boost"
Rob
er. i believe i have the right one.
it is t'd in near the boost solenoid valve.
i assumed that the more boost you bleed off the higher boost you will run - since you are trying to fool the system into thinking you are actually running less boost.
and no, i wasn;t revving it on the drive. i was caning it around in 3rd.
i just hate the way that my boost guage just shoots straight up to 6 psi, and thats it, it just sits there , at 6 bloody psi.
even when i fiddled with this bleed valve it just went straight to 7/8 psi and just sat there.
it gets to 5 in an instant, and then a few seconds later it hits 7 or 8.
bloody arse.
maybe my guage is a bit dodgy.
its a graham goode , basic mechanical type thing.t'd off on the intake plenum just after the throttle valve thing , me thinks.
sod it, im off to bed,
cheers.
Veilside
If its anything like the Z then bleed valves on their own don't work. You need to use boost jets too. Can't remember exactly how they were connected on mine but I think one "pair" of actuator hoses had the boost jets whilst the other "pair" had the bleed valves. Can't remember the exact plumbing though
