loss of power.....
:confused: ok so fitted my DV's couple of weeks back..well 2 months but power is nothing like it was when i first had car (4 months ago) i use to have to pull away in 2nd but now it seems so much slower...could this be from the dumpvalves? i didnt expect it to change this much...help me! :(
Prolly a boost leak check for a leak, near where valves are fitted
if you've used the standard vac pipe from the recircs its probably split when you've changed it like said its probably a boost leak mate
