Engine oil???
Hi, Just recently bought my first Z, `92 manual TT, i want to drop the engine oil this weekend, whats the best oil to replace it with?
ย
cheers
ย
Dan
Nissan recommends a semi-synthetic 10w/40. If your car is standard then you wont go far wrong with that.
ย
You can also do a search of the forum as this topic has been covered many many times :)
I think nissan recomends 10w30 not 10w40, but they tend to recomend that for everything from a micra to a 350z.
ย
If i were you id put AT LEAST a 5w40 fully syn in it.
ย
Alot of people use castrol RS 10w60, as the higher second number represents the oils adility to stay thicker at high temperature, the first number represents the viscosity when cold.
ย
I use a fully syn 5w50 and found it to be fine.
ย
Everyone has differing opinions on oil, so consider the can of worms well and truely open!!
