Bit fed up......
Well I was out on the driveway testing the coil packs and they are all fine.
However I'm in need of a fresh injector now so non too happy, will my Zed be ready for Japshow now??????? :confused: :( :( :(
good luck hun.... i aint no expert.. but hope you sort it on time
are you sure its not the connector eileen ?
I've tested those as well mate they are fine and I have a whole set of connectors and coilpacks, as well.
I had a look at the faulty one it's covered in green verdigris or however you spell it. Clean that off then I got Prof to use his meter to check it's output and compare it with the other one's it's the only one with no output on the meter and the wiring connections looks doggy. No resistance whatsoever. :( :( :(
This one's by the look of it has been fiddled around with in the past. :(
I think its stuck open as there's a nice strong smell of petrol now as well.
I did the thing of puting a sparkplug and things together and it sparked all right. It's the blast injector that's stuck open leting in too much petrol and flooding it
Before you go the whole hog and replace the injector, check the wiring all the way back to the ECU connector.
Thanks Athene as I'm hoping to run him down the dragstrip for the first time, I've been really looking forward to it but been really scared as well.
Yep Andy have looked at some of it so far apart from the bit near the coil packs it looks okay it's the top bit and that corroded as far as I can tell and the pins that were all clogged up with the green verdigris.
The light beat me again I'll have to leave it now till thursday :(
Have you got an electrical signal at the injector connector??
Easy to check with a noid light.
hope you get it fixed and get to the meet
Thanks Lampy mate, I so want to run my Zed down the Pod.
