water leak
i have a water leak its right at the top of the engine on the same side as the battery at first i thought it was te matrix pipes but its on the other side of the engine and its only squirting out a little bit and aint usin much water and it only does it for about 2 minutes then stops competely till the next day does anyone have any ideas on the pipes that sit at the top on the passanger side cos its startin to p**s me off now :smw:
I had the same thing, done mine yesterday, mine was from the water pipe that goes to the passanger side turbo, but then i got a plenum by pass so was easy to find as its the only water pipe that side
see if this helps
i forgot to mention, its right at the back of the engine and ya cant see where its comin from at all unless you have a head the size of a golf ball lol
it will be the little ******* running down the back of the bellhousing about 6" long and is a **** to do! LOL
it feeds the NS turbo best way is from below, use a long pair of thin nose forceps to grip on to the the metal clamps, fiddly but doable with plenum on just be patient
greg
pic for you!
look at hose's in circle check them, but im pretty sure it will be the hose that runs at 45o to the bellhousing clutch cover in pic
thanks greg you are a fookin hero it dont actually look that bad to do BUT time will tell i'll let ya know how i get on, thanks again greg.
