110c water temp !!!!!!
According to datascan my water temp is 110c !!!!!
the temp gauge on the dash stays in the middle.
I have recently cleaned the temp sender as i was getting code 13,
i get code 55 my question is if the sender is not faulty what could cause such high temps?
I will buy a new sender & try that
Problem now solved temp around 80c
heres how we did it. Reset ecu re-tested from flat cold started temp 90c...
So then took off connection for ecu temp sender reading should be minus ..
but started att 22c rising to 56c.... so there was the problem either the connection socket or ecu . Resoldered new connection socked coated wire with heatsheild cable. & now the temp is perfect !! :hyper:
But still only boosting standard boost 7psi :headvswal
But narrowing down the culprit :D
  • 4 weeks later...
martin, please return my money, thanks
brakes posted today, sorry 4 delay :)
