wozzer...
here is a pic of the dump valve thingy... (as per conversation the other night)
:confused:
looks like a hks/hks copy blow off valve to me :)
you need 2 of them ;)
lol.. i do have two of them!
but do they just go on.. or is there something missing!
they replace the recircs, remove them and connect these to where the recircs went, then t-piece the bits of vacuum pipe and them run them to a vacuum point, ie plenum etc :)
wow.. sounds simple enough... :confused:
Thanks.... they might just have to sit in the kitchen for a little longer...
its not overly hard :) if you lived closer i would do it for you ;)
you can do it with the nose panel removed but its alot easier with the front bumper off.
Good luck
Mike
hi babe'as ....
just bring them to billing and we ( most of the club ) will put them on for yay ....
:D ...
awe legend!
thank you!!!
Beer on me! xxx
hi babe'as ....
:D ...
Your on your own, hero boy!!! LMAO
YOU EVER SEEN THESE BEFORE...pmsl ....
Seen em, dont like them though!
OR is it they DON'T like you .... :rofl: :rofl: :x:
:rofl: :rofl:
Little bit of column A, a little bit of column B!!!
I go for a bit of Column C ..to be fair ... :x:
Whats that then???
THE one in the middle .... :rofl: :rofl:
he's a young lad so give him time ....lol;;;;
:confused:
They are hks, Ive just fitted a pair to mine and there is a bit missing!! (well sort of) there should be 2 'end pipe plugs (1 for each bov) you will need these to make it all work properly (Unless someone wants to tell me different, which is what normally happens) :headvswal
