TT Fuel pump = bosch???
Is the TT fuel pump is a bosch, and what is the bosch number?
Is it rated to 255lph?
I have a NA Fuel pump and a NA fuel controller will the TT units fit "bolt on"??
Do I have to do modification to make it fit???
You might as well use the NA fuel pump unless you hvae some very serious modifications to your NA?
Just buy a used TT pump and fuel pump controller, problem solved! You will need new O rings as well when you replace the pump?
Can't remember the brand of pump but IIRC I don't think it is Bosch!
