Replace Clutch??
In the next week or so I am having engine out ,upgrade turbos fitted along with sep wastegates,testpipes.The release bearing on my clutch is whining and I expect that I must install a new more powerful clutch.Any advice gratefully appreciated.I don't intend to drag or drift with the new setup(Honestly :D )just need this to work well to say 400bhp.Oh...and I need it to be cheap as possible
cheap as possible dont go hand in hand with a decent clutch
idealy go for an rps sport which will be happy with 400hp allday long, and lasts very well, the kit should contain a new release bearing, spigot, and alignment tool
cost would be around £300 smithy on here sell them.
greg
greg
That sounds like a good price,thanks for the pointer
Thanks Greg :)
Yep my rule of thumb for supplying new clutches, and i've supplied a couple hundred now :D is if staying with 4 bolt tubs and standard injectors, the Sport will happliy do yer, 5 bolt tubs upwards and bigger injectors, then the Max series.
Clutch selection http://www.smithys-place.co.uk/clutch.php
Hope that helps
cheers
smithy
Thanks Greg :)
Hope that helps
cheers
smithy
Hey,thanks for that;I will call on Monday;looks like the puck and racing pivot.Cheers Rich
