Bonnet Louvres...
  • Replies 74
  • Views 2.7k
Thanks buddy! ;)
btw ..how much does the temp go down ..oil and water temp ..5/7 oC...???
Hmmm..if only ! I've got no shortage of cold air going in the front - just need to find a way to let the hot air escape, preferably without cutting into the bonnet cos imho I think they detract from the smooth lines which make the Zed look so good to start with.
No question they're a good idea though! It was almost certainly the heat that caused my old auto box to let go!
if your not to bothered about looks you can add a few washers under each bonnet strap this will then help heat escape and means you dont have to cut the bonnet
been down that road ...ermmm Nah ....
can the front scuttle area be modified to allow the heat to escape? chop into the bulkhead area at the top and remove the seal?
will you stop FOOKING about with seal's and just get the vent's ..FFS...
problem is bud, is keeping water out from the battery area, also the main ECU loom comes in from the bulkhead under the batter tray so not a good idea
greg
greg
see i tolled you ...pmsl ...
joel :tongue: ;)
joel :tongue: ;)
nope as the bonnet angles up slightly and water works its way from off the bonnet, slightly differant :smw:
DAM! thatll teach me for tryin to be clever ;) il get me coat...!
yeah here's the door ...pmsl ...
not with you in there... no way! :rofl: :rofl: :rofl:
YOU FECKING ...pmsl .....class ......
what are we still doing up?
well i'm fooking stoned and pi$$ed ...what's your reason ..?????
pmsl
looking for some new front calipers for the scoob as her current ones are fooked! also spending silly money on fancy looking sti rear lights/crystal front lights for it and trying to choose some 18's! im also considering sticking a 300zx.co.uk sticker on it to take the piss :)
bed time now though!
night night...pmsl ...lol
In all honesty I can't tell you in degrees C but the internal guage which I know is crap is not reading as High as it used to and also if you have been caining the nuts off your Z when you lift the bonnet up you can still touch the top plenum without burning your hand!! Before without vents you just couldn't touch the bugger!! Ouch!!
fook i have not laughed so much in ages :D class PS joely :duffer:
