protoj · 7 hours ago 7 hr
Hi all,
I am looking to get into 300zx ownership.
I would apreciate your advice and opinions on a couple of cars i was going to look at.
One in the for sale section "Awesome pearl white 300zxtt "
and another on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270127500998&category=18238&sspagename=rvi:1:1v_buy
After reading up on the FAQ's on what to look for i was going to look for a manual but most seem to be auto's, i have read about the poss issues with the auto box's which put me off at forst but please feel free to talk me round.
Any advice help or opinions good or bad would be greatly apreciated
