Silverstone track time
Looks like the track exposed the wear on my stock 17 year old suspension. :headvswal After seeing Silver Bullet carve through this same corner, I cant believe how much roll I was getting. Fuuny, but it didn't seem so bad in the right handers. Do you think a good pair of coilovers will sort it or is there possibly something wrong with the sway bar linkage?
hi bud ...
silverbullet's car is set 50/50 ..i.e. road/track....this set up it a bit hard for allday driving ......
but if you would like me to have a look for yay ...;)...
this is what ,we set up on silverbullet's car ( all fitting done by himself) Oh and a little from his dad...
this car is running Standard tub's too...
updated tech spec.........
THIS IS NO SHOW AND SHINE CAR!!!!!!!
IT DOES EXACTLY WHAT IT SAYS ON THE TIN!
ENGINE:
apexi air filter
apexi BOV's
under drive pulley
lightened and balenced fly
blitz DSBC (running at 18-20 psi with no probblems)
greddy hard pipes
john dixon chip
braided fuel lines
braided brake vaccum hoses
braded engine vaccum hoses
full silicone boost vaccum lines
fully renewed electrical conduate
koyo radiator
full under bonnet heat sheild
twin dump divorsed elbows
de-cat test pipes
EX box
twin single exit sports boxes
modified bespoke short shift gear stick with 4" travel
SUSPENTION:
Front...
top adjustable arms
adjustable tention rods
white line anti roll bar
KYB adjustable gas shocks with adjustable coil overs
poly transverse link bushes
poly anti roll bar bushes
strut brace
Rear...
top adjustable arms
KYB adjustablle gas shocks with adjustable coil overs
poly subframe bushes
poly diff bushes
poly anti roll bar link bushes
strut brace
BRAKES:
skyline GTR 34 brembo calipers front and rear
DBA gold cross drilled grooved and vented discs front and rear
GTR hawk pads front and rear
BF goodridge braided brake lines front and rear
brake master cylinder brace
WHEELS AND TYRES:
17" ultra light weight five spoke racing alloys
bridgestone rubbers......
235 front
255 rear
3mm spacers on front
5mm spacers on rear
INTERIOR:
standard full leather
3x A pillar pod ( water temp, oil preassure and boost gauge)
nismo clock set
nismo steering wheel and boss
alloy gear knob
HKS turbo timer
EXTERIOR:
doesnt matter as you will only see a blur!!!!!
this is not the fastest ZX around, IT IS A DRIVERS CAR!!!!AND at 400 on the fly with the set up shes running theres not much out there that will keep up on the track!!!!!
Quote from "" joelyp "".including silverbullet who managed to set his car on fire after being probably the fastest car on the track in his session well done chap!... :hyper: :hyper: :D
Yep, there's no doubt bullet's car was entering the complex at very high speed and then handling the corners with no drama. What brand adjustable coilover did you use?
blitz DSBC (running at 18-20 psi with no probblems)...
Hi Wozzer, how ya doing matey!!! :D
Just wanted to ask about your Boost Controller set up (in Silverbullet's zed).
I'm amazed you can get 20psi out of standard turbos.
Is he also running with standard injectors??
Surely if he's running anywhere near 18psi, his injectors won't be able to keep up and he'll be running very, very close to detonation?
KYB's and lowering spring's ...!!!!!!
hi bud ...;)
yeah ...20psi ..but not for too long( 1/4 mile ) ....it run's sweet @ 14/16psi (to be fair )
we will be at billing in july so come say hello and we can have a chat :D
thank's wozza ...
