Door Pin?
Hello all! My drivers side door is becoming a bit of a bugger to close lately, it's dropped slightly meaning it has to have a good slam to fully close it!! Does anyone know where I could get a door pin from to sort this problem out?? Many thanks!! ;)
Just had to fix mine , a 5 min job. All you need is 2 washers , find yourself two penny washers with about a 9 or 10 mm bore in the centre , take one bolt out of the bottom hinge where it bolts to the door but only loosen the other so it will keep the holes lined up, put your knee under the door and lift it up opening a gap between the door and hinge , slip a washer in there ( it would be handy if you have some with differing thicknesses , so you can find the a pair the right thickness, trial and error job ) put that bolt back in but again only loose , now do the same with the other bolt , now tighten everything back up , you dont have to worry that the door to wing alighnment will be out as the bolts have self centering shoulders on them and you can,t get it wrong :hyper:
I was lucky , the washers i used were spot and and my door doesnt drop a bit now :dance: :dance:
Not too clear cos of the grease but you can just make out the washers between the hinge and door .HTH
Thanks Boldy, that's a great help!! I'll give that ago as i'm sure i've got loads of washers in me shed!!! :D
