timing/ apexi set-up?
hi guys couple of questions if you can help please??
1, can you change boost gain rate on the apexi avcr? as it seems to take a while to create full boost!
2, does any one know what sort of timing i can run with this set-up? is it a case of advancing a degree at a time and listening for pinking then retarding a little?
my set up is:-
blitz sus induction
G reedy side mount i/c's
apexi boost controller
nismo 555 injectors
smithy's t28 hybrid turbo's
ported and flowed exhaust manilolds
split divorse down pipes
custom de-cat pipes
scorpion silencers
snow water / methanol injection :hyper:
any help gratefully recieved!
regards steven
any luck with the apexi setup?? got the same problem...
What ECU are you running. Its generally best to allow timing to be mapped with the ECU, rather than just increasing the base timing.
Not very familiar with the AVCR, do you have instruction manual, they are downloadable online if not.
Only got 0,4 bar boost with the apexi off.... Running with the cars soleniods connected now. Got about 0,7-0.8 bar then and felt like it boosted quicker on original soleniods than the apexi
