protoj · Tuesday at 18:48 1 day
Great to see another Z'er in my area.... Hope you had a good day (who ever you are) Plz get in touch as I am in the process of organising a Z meet in Ramsgate Harbour for August....All Z'ers welcome
Tata
Stepe
