- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi
Boost controller in question here is the Apexi AVC-R.
Today I replaced the auto door lock/interior lights fuse. It had a 15 amp fuse in it and I put the correct 10amp fuse in it. Lights worked ok and clock got reset. I then drove the car tonight and it was losing power when it got into about 0.7 boost (basically once the stock gauge reached about 0.7, the car just lost any power, seemed like the fuel supply had been cut off, kind of juddered a little. I checked the boost controller afterwards and it maxed out at 0.82 bar with 4152 revs. I have had slightly higher boost before, with revs above 5000, so something was definitely not right. Looking at the settings on the boost controller, it was set to OFF and looking at settings for A and B, these seemed to be on the defaults. I think A was on 0.8 bar with 50% duty. And B was on 0.65 bar with xxx% duty. However, I have not had the car long and today was the first time I actually pressed any buttons on the boost controller, so I don't know what its settings were. I believe it was set to run at 1.0 bar though.
Is it right that replacing a fuse would reset the boost controller, or does it sound like it might not be wired up correctly. Seems a bit strange to me. :confused:
Colin
