protoj ·
This morning my oil pressure gauge was acting weird.
Everytime I was turning right the pressure increase to 120 psi, when I was turning left it was decreasing to 30 psi.
In straight line it was varing from 50-100 psi
Usually it indicated between 20-70 psi.
Should I be worried???
Anyone have experience someting similar???
