Hi all
only boosting 7psi with aftermarket gauge, ran an ecu check got code 13, Engine Coolant Temp. Sensor.
I take it its the yellow plug at front of car, see pic, it seems quite loose.
I guess i need to replace this ?? please advise cheers :p
Yep, thats correct. Plug available from Nissan, MJP or 300zx Specialist garage.
Try cleaning any corrosion from the connectors, and You could do a tempoary DIY repair and cut of the connector and fit some spade connectors on (tape them over to stop them touching), but get new connector asap.
yep thats the one, have you tried cleaning the conx up abit
Well cleaned all the green crap off, & i got code 55...... i love this club :D
But still only 7psi ...................
well it must be a leak, some vacuum pipes are a little brittle, so i will change them next & hope it will sort it
