Problems Again
Hello All.
Well got my zed back on the road yesterday after suspension probs, anyway she was fine no probs at all however, got back home. after an hour or so went to go back out, started her no probs, but when rving her up it feels like the engine is unbalanced like the bloody engine is shaking. when you rev her its rubbish ( hesitant) like shes not firing properly after 3000rpm she goes ok. then when you go in gear ar idle and it feels as if she wants to die on me. any ideas??? I hoping fuel filter spark plugs or something like that. will do a ecu check in a minute and see if that turns anything up.
Dutchy
it appears that ive lost abit of coolant from somewhere, although temperature yesterday was holding in the middle of the gauge, looked undercar and got a small patch front passenger side of engine, rad is full and dipstick looks ok, puzzled or what???
unpluf each coilpack one at a time to see if you've lost a cylinder. the one that makes no difference to the idle is the problem one. Might kust be that one of them is loose.
Also check the ptu connection
job done or so it seems, had a play with the coil pack conx, and after that no probs
A very common fault. Replacing the connectors will help as the old ones will be corroded and the spring clips that hold them in place break off.
