advice with bt broadband
i need advice with my on going problem with bt i have been paying £27.99 for "8 meg" for well over a year. anyway my speed has been all over the place from 36kbps to 7.5 meg ever since i have had it then 2 weeks ago they tested my line speed and said i could only get 1 meg to which i said no i get 7.5, the problem with my line is causing it to say 1 meg. so he checked next door they could all get full speed. so he said phone technical help line and they would send an engineer out. three phone calls later and over an hour and half on the phone, im still no closer to getting my problem sorted they keep saying its your computer or its your router or some crap. so now im thinking of taking it further as i have been paying for a service that they havent given me, all my faults and calls are on there systems to prove it i have phone bills of all the calls to there "technical :rofl: " helpline which i want back too any ideas
  • Replies 40
  • Views 867
Copy your hub stats and post hem here and we can take it from there. I am also on BT and the hub is a little shit
how do i do that
BT are shite.
My mate had ongoing problems when he moved house. Using the exact same equipment/setup in the new house the connection constantly went off.
One time for a week!
All BT would say is "it must be your router/PC". *****x!
They just read the same script of excuses all the time. :xxx:
Eventually he forced them to get an engineer to check the line/exchange and they found a fault there.
is this what you mean
DSL Status: UP
DSL Modulation Mode: GDMT
DSL Path Mode: INTERLEAVED
Downstream Rate: 8128 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 13 db
Upstream Margin: 25 db
Downstream Line Attenuation: 19
Upstream Line Attenuation: 9
Downstream Transmit Power: 0
Upstream Transmit Power: 0
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
Qos: UBR
Pcr Rate: 0
Scr Rate: 0
Autodetect: Disable
VPI: 0
VCI: 38
Enable: Yes
PVC Status: Applied
More...
I am so envious :cry: , according to those stats you should be downloading at 8.1 Meg(ish), what is your actual download speed ?
Do you download a lot of films etc?
BT have a "fair usage" policy so they may be throttling you. So to speak.
no i dont download films i never go over or close to my limits
Looks like maybe some softwarwe is sapipng your bandwith
but it can be ok sometimes then it will drop off mainly after 5pm it does this through my mac, pc, 360, ps3, ds and my wii even if my computer isnt on
thats uplugging all the leads and turning it off as well as my pc isnt it
No just go to your browser or hub manager ad reset, or power cycle the hub
done 422kbps
"Apparently" according to BT you shold wait 3 - 10 days for the hub to stablise its connection speed, pisses you off but give it 5, then check your hub stats and see what it says
"Apparently" according to BT you shold wait 3 - 10 days for the hub to stablise its connection speed............
WARNING - Bulshite Alert!! (BT, not you Paul ;))
What the hell has to stabilise??
Sounds more like BT's way of getting you off their back for a week or so!!
it is bull shit i have waited 18 months for the fookin thing to stabilise and thats what they told me tonight aswell
Agreed, I used to have a crappy USB modem and that didn't need to "stabalsie" max speed all the time on that
OK, now pull the power from you hub, leave it 30secs+ and wair for it to reconnect
done that and reset my pc for the same time
Last Result:
Download Speed: 529 kbps (66.1 KB/sec transfer rate)
Upload Speed: 376 kbps (47 KB/sec transfer rate)
thing is i never had one problem when i was on 2 meg all started once they put me on "bt max" :xxx:
