can i run the zed with 1 dump valve if so will it make any difference to the way the car runs
:rofl:
is that a yes or no
has been done, there is a picture about somewhere i guess apart from it proberbly being fooking loud i dont see the point as all the plumbing will need to be changed, buy 2 you skin flint :rofl: :rofl:
well i have a pair of ARC's on at the minute and they aint loud at all but i have a TCC WORKS 1 that is really loud and was thinkin of puttin that on 1 side and leaving 1 of the ARC's on the other would this work
not sure about that as 1 might work at a different pressure so may cause an imballence in pressure release
I know what you mean i guess there is only 1 way to find out i did have 2 and i sold 1 to a mate and now i cant get another cos they came from the states and i cant find the website
should it matter running 2 different types cos someone else has told me that as long as the springs can cope with the pressure it should be ok cos its only to dispurse unspent air does this sound right ?????
not sure about that as 1 might work at a different pressure so may cause an imballence in pressure release[/
i think that should answer your question.
well i've found another 1 on fleebay so i'll have to see if i can get that 1 thanks for your help guys
not necessarily as some dump valves are adjustable either by a skrew at the back or by placing shims behind the spring to adjust the spring tension
Didn't you ask about this a while ago?
Basically it's possible but why go to all the effort of making up the pipework etc when you could just buy a pair LOL
well like said before chris i did have a pair but i stupidly sold 1 (Doh) cos i was'nt gonna bother but now i want to fit them i'll just have to see if i get this matching 1 off ebay.
yey i won the dump valve off ebay so i'm well pleased i'm gonna make the T-peice's in the garage this weekend and hey presto a nice matching pair. Chris if your going to the meet i'll show you them they look really nice, thanks for the help lads.
see since we're on the topic of dump valves, does anyone know where you can get a set specifically for the 300zx, with the required pipework?
cheers
theres a zed breaking on ebay with all the blue silicone hoses and a pair of blitz bov's
