Low beam / Main beam
Is it an easy job to wire my headlights so as the low beam stays on when the main beam is switched on? I could just wire it so it works but would I have to wire any more relays or anything into the circuit? Someone said I would have to use heavier duty wires?
Vini
  • Replies 26
  • Views 1k
Yup, that's right. If plugging it up to the body doesnt work then just plug it direct to the battery like mine.
Just dont flash the high beams with the low beams off. Like I've said before, the only time you'll be doing that is during the day! In which case a nice hand gesture will do fine!
Cheerz Wing,I can defo understand that LOL. ;)
