KYB AGX Shocks question
Fitted these last year and they are currently still at the default settings.
What I would like to know which way is to make the shock harder and softer?
Front 1-4 set to 2
Rear 1-8 set to 4
Pete
Front 1-4 set to 2
Rear 1-8 set to 4
Pete
4 on the fronts is firmest m8
8 on the back also firmest
:confused:
your right i DID put 4+8 on my first post then edited it :p
and was watching summat on telly :nelson:
No, 1 is softest and 4/8 is firmest.
Lowest setting is 15% softer than stock* and the highest setting is 40% firmer that stock.
* Aftermarket springs will be firmer than stock springs, so even on softest shock settings the springs may make it firmer than stock still.
