Dam! Change ptu, but engines still cuts out & dies...
I'v just changed the ptu, and the dam thing still aint running right.
Starts ok then sits at idle and then engine just dies... Ignition lights on..
Starts again... Runs on idle.. Then dies again.
PCV valves?
Or just a service?
Both... :wack:
PCV valves?
Or just a service?
Both... :wack:
Have you checked your coil packs ?? could be the MAF also do a search on coil pack checking and see if you can borrow a MAF from some one ..good luck mate ( what error codes are you getting up from the ecu?? )
Steve
Steve
Hi mate,
Ok... I'm a bit of a novice me.
So whats a MAF?
Where do i check the ecu error codes? What am i looking for?
Cheers m8.
Pete
Hmmmm if you were a bit closer I would come round with a Conzult.
I may be passing through Reading next week so if you are still in trouble there is a possibility I could stop by and hook the laptop up.
Mate! Your a trooper for sure! :)
If she's still sat there is the same shape as she is now by next week i'll let you know.
Any advice/help is appreciated big time.
And if you need a new mobile, i could help you out.
:) no problem
you can check your ecu codes manually to start i reckon.
Find the plug in the drivers footwell near the bonnet release handle. Jump the two end pins together (hair-clip, paper-clip, short wire) you will see the engine warning light start flashing.
Count the short and long flashes and that gives the codes. 55 (5 long, 5 short) is all clear.
:) no problem
Hiya mate,
just tried and the dash lights went off completely...
Just checking fuses! :smash:
Helps if i read your post completely! lol
consultport.jpg ;)
Sorry, should have explained that a bit better!
Ok Ollie, sorted mate.
Ecu code is 55...
I thing i have noticed, is the 'slurp slurp' noises have gone...
Is this the PCV valve blocked poss'?
Pete
PCV valves?
Or just a service?
Both... :wack:
This might be irrelevant but, a few years ago I had the PTU symptoms. Took it to a Nissan dealer & they put a new PTU in (but it was a Series 1 PTU - I didn't know any different at the time). 6 weeks later, the problem was back, so I presumed it wasn't the PTU (even though it had all the normal PTU symptoms). Took it to a few different places & spent plenty of money replacing other stuff - obviously it made no difference. I ended up buying another car while my 300 just stood in the garage, pissing me off. After several years, I heard about the Series 2 PTU and got one from Luke last year. Problem solved, and the car is fine. :D
So, long shot - was your new PTU a series 1 or 2?
Alright dude.
New 1 is a series 2 PTU, which i fitted at lunch time, thought it would run fine after fitting, but nope, not a chance. Took her down the road and she's aint a happy bunny that's fer sure...
So next step is PCV valves and see if they're blocked and need cleaning / replacing... Spannering a car like the TT is new to me, so i'm learning as i go. :smash:
Fun tho' so i dont mind. :dance:
Seems like fuel starvation 2 me, she runs ok, but then gets all shitty and then dies. Its def not the pump or fuel reg as they are brand spankin.
Hello bud,
If I was you I would get some contact cleaner and start by cleaning every connector you can get to in the engine bay. I had what looked like PTU problems and it turned out to be the CAS connector was dirty and caused my car to cut out ;)
Vijay
Hello bud,
Vijay
Alright Vijay,
you could be onto something there bro', when i took the old ptu out, the connectors on 1 end were very corroded... :wack:
Think i'll go and whip it out again now and start now as i wont be able to get on her again till Friday.
Cheers dude. :dance:
Alright Vijay,
Just waiting for the MODS to miss understand LOL.
Good luck with it mate. It is very frustrating when these things happen.
Darrell
Darrell
lol...
Inuendo's, u just gotta luv em... :D
Cheers Darrell.
Get a small sharp screwdriver and really scrape off the gunk from the lugs in the connectors.
A good spray of WD40 will do the trick. Try to do every connector you can see.
Also wiggle all the wiring loom just to check its not old corroded wires. (I had your same problem when I first got the zed, brand new loom sorted it in the end.)
Cheers ollie, thats exactly what i have planned for fri / w/e. :xxx:
:D
check the engine cont fuse in the engine bay.
Hi m8, yep planning on going throught the electrics this w/e. :smash:
Should be eductional! :D
Cheers,
Pete
