Running wires from engine bay for pillar pod
I looked to run my temp sensor wire and boost pipe for my pillar pod through the inner wing but that looks a PITA. There is a small plate on the left hand side beside the brake pedal would I be right in saying its where the clutch pedal goes through the bulkhead. I am guessing it wouldnt be a problem to drill a hole for the wire/boost pipe. Anyone verify this for me or is there any easier place to run them.
Cheers John
I did a search but never found anything like that. Cheers for that just what I need.
Cheers John
  • 1 month later...
There's a gromit in the passenger foot well behind the ecu. Its really easily access. Just remove the passenger side arch liner and you'll see it right there. You can drop the amp wire straight down the inside of the wing, through the grommit into the cockpit.
Dead link...sorry to bump, but was searching.
So...wanting to run a power cable for my new sub through from battery tray into the car via the bulkhead without drilling etc. Any gen would be good thanks.
Trace the bonnet release cable. This goes through a rubber grommet on the drivers side. You can make additional holes through this using a wire coat hanger and then pull cables thru'. Will need to remove drivers footwell trim as well.
I managed to get my sub power cable and all the wiring nescessary for 3 additional gauges. :D
Trace the engine release cable. :D
****s sake all this time, engine out 3 times and now someone tells me there is a release catch for it!!
Well that would have made me life easier.. I am guessing you just pull the catch and pop! out comes the engine yeah? :hyper:
pmsl sorry dude couldnt help meself :D :mac1: :nelson: :x:
:rofl: :rofl: :rofl: :duffer:
Speedfreak 1 Apache 0 :bow: :rofl: :duffer:
do what i did , run a dedicated power and earth supply through to the cabin. fused it with a 100amp circuit breaker.Then whenever you need power in the cabit...et voila
