protoj · 8 hours ago 8 hr
Im in the process of setting up my boost controller, would anyone with the profec be so kind 2 share there settings with me.. im looking for something that will give me 12 to 14 psi....
i know everycars different ... so if your running stock turbos and upgraded ics plz give us your settings
even stock and stock is good
profec B spec2..
set = %
gain = %
set gain =
warning =
warning limiter = %
