foglight fitting
hi peeps
got my mot tommorrow and ive just realised i forgot to fit a foglight......whats the easiest way to do it ive got the light but do you tap into the switch or the front foglight wires
cheers in advance
matty
Didn't it have one fitted after being imported then?
Thought the SVC test required one?
Or have you been modding a UK one or something?
hi mate
when i changed the rear lights one of the reversing lights had been changed to a foglight with a red bulb but it wont work with the new lights so i got a small foglight that seperate
Ah, there you go, didn't think of that one LOL.
I assume you've still got the feed to the old fog light bulb then. Just use that.
yeah found the feed but it doesnt work and disapears under the carpet somewhere
Did you have an extra switch fitted somewhere for the 'new' fog light?
no mate i was going to tap into either the switch on the pod or the plug behind the pod or at the front of the car where the foglights are
Mine's been tapped off the 12v wire that goes to the switch in the pod and then has a seperate switch to control the rear fogs.
you also need a fog light tell tale light for mot, can be part of switch or seperate but must come on with fog lamp.
