greddy profec b spec II install
Is there a definitive guide out there for installing one of these? I’ve had a look at a guide on this forum but the minimum boost would be set at 9 psi instead of 7psi and you also need loads more silicon tubing. Do you need extra tubing etc to install the profec b spec 2 in a 300zx. I would prefer a guide that is step by step and has pics. Or alternatively someone who lives near me to come help or to do it :tongue: .
Paul
Paul
not sure if what you want is here m8??
http://www.300zx.co.uk/forums/showthread.php?t=68133
I used this guide CLICK HERE and found it easy to follow. It can be done in a couple of hours depending on where you fit the unit. I spent between 4 and 5 hours doing mine but that included going out and getting the extra pipe and T pieces.
Don't forget to unplug the stock solenoids like I did as you get about 14psi no matter what :smash:
Thanks this is what i was looking for.
Thanks for all the help guys.
Paul
