Wiring LED's
Got to solder in a large quantity of LED's and they come with a pack of resistors, so I can feed them off a 12v supply. My question is can I just use the 1 resistor on the main feed wire or do I have to use 1 resistor per LED? Will it effect brighness?
Vijay
  • Replies 37
  • Views 1.4k
Vijay .. u will only need 3 leds in series .. this will give 4v to each LED .. no resistors needed
No, MAX 2.3v forward voltage per led! ;)
*****x .. that'l teach me to "flick read through " :xxx: :smash: :tongue: :dance:
200 Ohm for each row of 5 wired in series :) When the car is running the battery voltage is 14v, so 4 Volt drop required @ 20mA
4/0.02=200
At no point did he say this was running from a car -he said a 12v supply ! ;)
sorry, it is from a car and thanks to everyone :)
you're all a bunch of geeks :x:
Says the "man" in a bungle outfit :x: :rofl: ;)
roflpmsl :rofl:
Missed this thread yesterday, send me a PM with what you are planning and i'l let you know what to do. :)
OK, back to this again. What size resistor would I need if I had 4 of these LED's in series and 3 LED's in series?
Vijay
Vijay
3 LED needs 415 ohm so nearest available is 470ohm
4 LED needs 320ohm so neerest available is 330ohm
1/4 watt should do
[sIGPIC][/sIGPIC]
