idle problems
When I start from cold she is hesitating, if you leave the accelerator in the same position it picks up and then hesitates etc. Then when warmed up and with A/C off the revs keeps dropping right down to just above stalling speed, the engine just about keeps idling. Sometimes the idle speed goes to high as well! When the A/C is on when warm, the idle seems ok most of the time, but sometimes too high.
Clean your connector for the coolant temperature. It's at the front of the engine and it's yellow. Also check yout throttle position sensor.
Mine was the same and this worked a treat.
Cheers.
Cheers.
Thanks m8, sorry it's a bit late but computer down at mo, have to go to the library when I can!
