- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
1. I recently did the clear rear indicator conversion. only done one side so far but all went fine but strangely now every time i switch on the lights the rear light doesnt come on (either both bulbs or one or other of them) and i have to go round to the rear and give the unit a tap on the front and it is fine. tried looking for a loose connection but cant find anything. Anyone heard of this problem before?
2. I tried to check the ecu error codes but shorting the two pins on the consult plug with a paper clip i was short on space and couldnt really see what was going on with the light but now the yellow engine light does not flash on at all when i turn the ignition on like it is meant to with the battery light etc. I guess this is not a good idea that this light isnt working if i do develop and engine fault. everything else seems fine. is there a fuse that just controls this light?
