should these brakes fit?
If yer interested in the K-sport big brake kits mate, can supply the 330mm 8 pot kit for £850.00 and the 356mm 8 pot kit for £990.00. Upgrading from the K-Sport to Ferodo DS2500 pads with these kits is an extra £65 ;)
cheeers
smithy
Smithy,
What size pads does the kit use and any feedback from people with it fitted to the 300zx?
No feed back as such from Zedders as am only aware of 2 peeps having it and neither are on this forum, the kits are the Skyline GTR kits and small number of them are using it and from what i've read all seems good, oh and a handfull of s14 guys on the sxoc use em :)
Pad size, without having a set here to hand fraid i couldn't tell yer, these kits were only offered to me 2 days ago... can ask though, you wanting length, thickness, width or summitt ?
cheers
smithy
i was interested in the pad dimensions so i could compare to other BBK, as though they are 8 pot the caliper looks quite small.
I'm quite interested as it seems an easy way to move up to 2 piece disks.
No probs mate, have asked that question for yer and wil let you know soon as.
smithy
pad dimensions are AP kit pad 90x147mm, K Sport pad 85x145mm, approximate.
erm hope that helps bud.
cheers
smithy
would the 356mm fit under an 182 wheel?
what internal diameter is required?
cheers
smithy
thanks, so they're bigger than they look then! Don't suppose you have templates so we can check wheel clearance?
Mark, 330mm are for 17in wheels and 355mm are for 18 in wheels, obviously it's dependant sometimes on actual wheel design. I have though asked for what the minimum space required is for the rear of wheel for each size listed.
Is that also what you wanna know Jaffa ?
smithy
yup so I can check the clearance with the spokes :)
I'll see what i can do, BUT the only company I know who do this is AP. So don't hold yer breath bud :)
cheers
smithy
stoptech do it too :) but no worries. I'd like to go for the 356 but concerned about clearance
