April 12, 200719 yr been offered a set of alloys they are 19 inch and from a lexus is200 will these fit my J spec TT and will the offset and stud pattern be ok? also will spacers be needede, many thanks in advance for your help!
April 12, 200719 yr My alloys on the zed I sold were lexus alloys and they do fit ok but needed a bit of modifying as the centre needed to be bored out. Give Ronflat a pm as he's the guy who sold them to me and sorted it all.
April 12, 200719 yr No worries. I found the Old PM where he told me about the problem. I know its meant to be a private message but in this case I'm sure he won't mind: ย Originally Posted by ronflat "Yes I have news, they have all been repolished, the PCD (stud spacing) is spot on as is the offset. So I was going to put the wheels on to send you a picture. However one minor problem, the hub centre is fractionally bigger than the centre of the wheel, only by 2mm. So they are machining it out on Wednesday. So just need 2mm more width by approx 6mm deep. To be honest here its not a problem as the metal in that area is massive, plenty to go over 10mm wider, so 2mm is nothing. Just going to cost me another ยฃ40 to get them finished now."
