Clutch~ Zed is not moving
Ok jumped in the car this morning to go to work, now the gear stick in the last few weeks has been a bit stiff every now and then, especially in 1st
Though this morning it would not go into first or reverse or anything :rant:
So i got the bus to work
jeez how many more things
The clutch is relatively new RPS street clutch with a uprated pivot ball
I had some air in it after it was fitted, is that the problem again?
or is it somit like this below though my symptoms it is worse when cold
so bad I ain't moving now
arrggghhhhhhh :D :rant: :cry:
link to clutch stuff issues
Sounds like it needs a good bleed Emy.Dont forget the pipe that runs to the front of drivers side wing in engine bay.If you was abit nearer Nottingham I could ask my M8 to sort it for you as he owns his own clutch and gearbox centre.He would suck out all your fluid and fill it up from underneath so you defo dont get any air in your system.
Thanks Sweetie, tried again it ain't moving, sounds like you said as it hasn't got any other symptoms, well I just bought myself a bus pass for the week as I wouildn't know where to start :cry: :(
if i could drive to Nottingham I would...... Slick Pete gonna sort out my suspension after Easter, though at the mo not going anywhere :rant:
well my pathetic attempts to pump the clutch :confused: :o , Rob
not really ther gears did last week when it was getting a bit stiff, mind you first gear has always been like that,
sounds like it needs a good bleed
Exact same problem as a mate of mine has got. He tried bleeding it all but no luck. He put in a new stage 3 clutch just a couple of days before his stopped going into gear. Now he is looking to try the process of elimination by changing all things involved in the clutch system e.g. the cylinders and all. Do keep us posted how it goes with you and if my mate has any luck with his, I'll let you know. ;)
Theres always "THE TAMWORTH PIGMY" :D :D :D :slap:
Well try pumping fast and full travel of the clutch, then hold down, then try selecting a gear.
Mine had this prob last time i had engine/gearbox out and back in. Tried filling system from bottom, no good. tried all 3 bleed points, no good.
In the end my dad sat in the car me underneath the car. I pushed in the slave cylinder all the way in by hand, the master cylinder made a clunk sound (1 way valve maybe??) and the clutch was perfect! :confused: Never had a problem since.
No honey
oh god no thanks.... spent 3 grand with him to fix my car (yes extorinate) didn't even get jigged, though he said it had been done :slap:
He just saw the money..... no honour or professionalism :xxx:
Then spend another 2 grand elsewhere fixing the mess he made
I'll have a go tonight, though day of hell at work, I feel quite tired and the thought of pumping a clutch fills me with so much joy :rolleyes:
EXACTLY the same as mine. New RPS clutch fitted by people I now consider to be con-artists (thankfully no longer advertising on this site). Started with first gear but got worse over about six months and a garage I trust has just diagnosed that I need a new clutch master cylinder.
£210. Too much for this month as i just spent loads on repairing other bits on the car. I am trying to think of bits on my zed that have not gone wrong and I am now struggling. :mad:
I love the car but maybe zed ownership is coming to a close for something a bit more reliable. :mad: :mad: :mad: :mad:
Exactly what my mate has been looking for to get his back on the road. Think he is going to have to go for a brand new one too from Nissan maybe as no way they can be found else where. I've tried.
Recently had to buy a new master cylinder from my local Nissan Dealer £75 ish pounds.Was quite surprised at the price.
that sounds promising,
tried pumping the clutch this morning and hey hoh absolutely nothing
just gonna save up and sort out the stuff all at once
Vinz would you pm the phone number for the slave thingy I'll ring my local dealer too and see how much they are
It will be the same at any Nissan Dealer Babe just give them your car spec .
PS. the master cylinder is around £75.00 as a complete unit.Thats at rear of engine bay bolted to the fire-wall got the little pull off cap you use to top up fluid.The slave unit is under neath car bolted to side of gear box.Seal kit for that is around £8.50. HTH........Vinz
  • 2 months later...
Mine is done, slave needed doing as well, should have known it was not going to be easy!!!
