off sets.
I no theres been alot of post on this latley but to be honest i dont understand how it all work so wo#hat would be needed to fit these on a zed if they would go at all??
The front wheels are 8.5 x 19 with an offset of 41.9. The rear are 11 x 19 with an offset of 55.3.
thanks graeme
fronts are ok, though you'd probably want a 5mm spacer for a better fit.
Rears are too wide unless you have a wide arse, max is about 10" on the rear on stock arches. The offest is quite high too so even you roll the arches you'd need 10-20mm spacer on the rear to stop it hitting the suspension
