Me again.
So I have two questions:
RobHowl ·
does anyone no the wire colours to set up my turbo timer type 1(khs),bought a harness which is the correct 1 but it still doesnt fit?
anyhelp would be appreciated.
jaylox
[This message has been edited by jaylox (edited 22-05-2002).]
