On my quest to find out what would cause high levels of H/C as they need to go down here's a few things I need to confirm.
Code 13, makes the car run in safe mode, I take it this means it'll dump more fuel into the engine, hence the higher chances of the fuel not fully burning and ending up with an exhaust fume smelling more like petrol!
O2 sensors, if they are shot, would it do the same as above?
Also, after driving for periods of time with the engine dumping more fuel then needed, I guess my cats would be dead!?
Any help would be nice cheers!
13 is water temp sender i think
Yes your car would over fuel if the ecu doesnt know the water temp
Do you have a standard ECU chip?
Vijay
I'm assuming so but I've never opened it up and checked personally.
