dam bulb
hi guys
just a quick question i have a side light out on my j spec and cant get the plastic cover off to get at the bulb any ideas. the manual says there is two screws but there is only the one and it just turns has anyone had this happen, do you need to prive it with something as you turn the screw ?.
Ps just had my 18s fitted and a full respray pics to follow
hi guys
My guess is that the screw you are turning is in fact the light alignment screw.
What you need to do is remove the corner indicator units (two screws). Stick your hand to where the sidelight/foglight housing is and you'll feel three nuts. If memory serves me these are all 10mm nuts. Undo these and the light housing can be pushed forward and out of the bumper. Then it is a matter of undoing the four screws which hold the light backing to the front glass and this will give you access to the light bulbs. BTW: side light is 501/5W type and fog light is H3 but with a bullet connector not spade.
Dan
the screw adjusts the beam angle
unscrew the indicator next to it (2 screws)
reach in through where the indicator was with a short 10mm spanner and undo the 3 nuts on the back of the side light, remove sidelight, undo the 4 screws on the back, and open the unit up
[sIGPIC][/sIGPIC]
