My indicators don't work
I have changed the fuse. What fun that was. My hazzards and High beams work but no indicatirs. any suggestions.
Konrad
Check the hazzard switch is returning to the off position fully because if not the indicators do not work, usually the fixings in the pod are the problem as it causes the hazzard switch to get jammed.
Daveman
The indicators have a seperate fuse from the hazards , and ( presumably ) the main beam .
B*gger , just remembered , that was my ole Prelude . Still , could be a similar set-up in the Zed ....I stand to be stoned to death and corrected . :D
hazard switch definitely most likely cause - had same problem on mine as the plastic mounts had snapped so the switch couldn't quite return to the off position!
Daveman
Wow! thats exactly what it was. Thanks a million.
Konrad
