Brembo Calipers
Finally got hold of some R33 GTR calipers and have now run in some Ferodo Pads, drove down to Southampton at the weekend......wow what a difference now the car dips on it's nose and really stops as it should...however i have a little vibration when i do brake which could mean warped discs?????
Look to see if the tie bar bushes appear wet or have sticky fluid dripping from them. I had the same problem. Bushes were perfect until the R33s went on - the increased braking force tore the bushes to pieces...
Running forwards to the radiator support from each front lower wishbone. End with the bush is at the front...
are R33 calipers the same as R32?
no, R32 are the same as the Z32. Only the R33 & R34's are upgrades
oh right, nearly woopsied then lol.
What is different between the R32 and R33. Also are the R33 the same as the R34 then?
Thanks.
Thanks.
r32 are same nissan calipers as z32. r33 use black or red brembo calipers, r34 use gold brembo calipers, difference between 33 and 34, nowt except the fixing bolt holes are 14mm on the 34 and 12mm on the 33, other than that they are the same caliper.
cheers
smithy
