Ok this is the same problem I've had since a friend of mine and I replaced the brake master cylinder seals a while ago.
Basically when the car is left for longer than 24 hours all the pressure in the clutch disappears. Now, I have no leaks anywhere and the fluid isn't dropping but still I lose all the pressure in my pedal.
I think I have air trapped somewhere but a friend has told me that by emptying the system when i bled it to replace the master seals, I could have disturbed the seals in the slave cylinder and it could be a bit knackered! Is this correct?
Also I have not modified the slave to master fluid line so I am still using the half flexible half hard hose that the car was built with that a lot of people seem to have problems with. Will it make a difference if I replace it?
I have bled the system countless times using the Nissan Service Manual procedure and it still doesn't work, but also doesn't appear to have any air in it. I'm a mu whits end because I can't drive the thing. Even when i've pressurised it by pumping and pumping I can't change down from 5th to 4th i have to pump an pump again. Someone please help cos i'm sick of this now!!
Hey guys,
:headvswal
Kind Regards
Rich
knight_rider
