throttle body unit
the revs on my n\a were all over the place on tic over so i changed the tbu for a re conditioned 1 .this hasnt solved the problem much.
i did only change the half of the unit ............the non electrical side.
could it b the other side thats giving me problems
help please as every body thinks i'm reving the nuts out of my car while sat at lights :bow: :bow: and zebras :headvswal :headvswal :headvswal
PTU? Power Transistor Unit? How can you only change half of it?
the thingiy that u r supposed to clean with carb or brake cleaner..........
might not be called that thou
Throttle bodies
Probably idle valve (9). Clean the throttle bodies instead - 22 on the above pic, one on each side - do both
26 or 27 are the connectors for the passenger side O2 sensor and the passenger side VTC solenoid?
when i changed this it was right be side the battery which i had to take out.
it was a right ******* to remove and it was around the area of 27 , 26 and 9, albeit, under them
ok just dug out the invoice and its down as a aux air valve.
so clean the throttle bodies instead??
thats what i thought i was doing b4.
give it go tomorrow.....any tips
and thanx for the help
There's a few guides on doing the TBs, will have a look for you now :)
http://www.twinturbo.net/ttnettech/tb/tb.html
Tip - while the boost hoses are off, leave them on a radiator in your house to keep them warm and flexible ;)
yep. got a print out of how to do it .
thanx for ur help
looks easy enough . hahaha ....u never no with me thou
cheers
radiator in spain, i will have to look for one of them.
