cam diffrence in auto / manual
ok gents this is for the techies :dance:
right then my uk auto zed has a new engine fitted but it is a manual engine, im still using the same ecu with a dixons chip, nothing wild :smash:
i have just read this & it got me thinking :rolleyes:
"Aside from minor changes in the ECU, the cam profiles & turbos are also different between the M/T & A/T models. The A/T has 240 degree intake cams & 248 degree exhaust cams (the M/T has 248 degree cams for both intake & exhaust). Also, the A/T uses smaller turbos for more responsive low speed acceleration (the A/R ratio is 0.63 for the M/T & only 0.54 for the A/T). Even with 20HP less, the A/T turbo is capable of beating the M/T turbo to 100MPH."
my question is this:- am i ok using the same auto ecu with the dixons chip? with regards to the diffrence in cams ??
im running 14psi by the way
cheers
dewi
cheers chris, just wanna be 100% had a bad experience with a chip that blew a hole in my piston see
